clear ip-security anomaly-protection notify cache
clear ip-security anomaly-protection notify cache {slot [slot | all ]}
Description
Clear the local protocol anomaly event cache.
Syntax Description
slot Specifies the slot to be used.
all Specifies all IP addresses, or all IP addresses in a particular state.
Default
N/A.
Usage Guidelines
This command clears the local protocol anomaly event cache.
This command was first available in ExtremeXOS 12.0.
Platform Availability
